84 berlinetta dash swap and steering column? help
Old Dec 17, 2012 | 07:28 PM
ajslay's Avatar
Car: 1985 berlinetta
Engine: 305 carbureted
Transmission: 5 speed from a '97 trans am
i have an 84 berlinetta with a 350 and a 700r4 with a stage 3 shift kit, i hate this stupid digital dash. can i get rid of it and go all autometer mechanical gauges?
and as for the left and right pods... half of the buttons dont work. i know they just need the solder reflowed on them but i would like to get rid of them if i can and go with a regular style heater control
and i hate the turn signal switch on it, could i just wire in a 3 way toggle switch?
please if anyone has info it would be appreciated. thanks.
Old Dec 18, 2012 | 11:07 PM
ajslay's Avatar
Re: 84 berlinetta custom cluster and pod delete?
how hard woud it be to swap the dash from another thirdgen into this one along with a steering column?
Old Dec 19, 2012 | 10:17 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 84 berlinetta dash swap and steering column? help
Here's some info when swpping from Berlinetta to something else....
https://www.thirdgen.org/forums/inte...uage-swap.html
Here's some info when swapping from something else to a Berlinetta.
https://www.thirdgen.org/forums/elec...uges-86-a.html
An 85-86 donor car appears to be the best match for a Berlinetta conversion. There should be enough info in those liks to give you an idea at what's involved.
Old Dec 19, 2012 | 07:14 PM
ajslay's Avatar
wow thanks alot dude, il take a look at those
i dont have the cash to buy a parts car, but i could go to my local wrench n go and get a lot of those things i think. hopefully that would work
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
