Steering Column Woes
Old Dec 18, 2012 | 05:04 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
where to begin...
Lets start with the steering wheel moves in a circle (not like it suppose to) it goes left, right, up, and down laterally.Tore it down, could only get to 2 of the screws (any tricks to get the other two?). Put it all back together, doesn't move as much but now the brights dont work (switch worked before being tightened into the cradle). And when the headlights are turned on the right turn signal light comes on, doesn't blink just on.
Here are a few Qs I have:
1.) what is the secret to get at all 4 of the lower housing bolts to tighten up the steering wheel?
2.) How can I adjust my bright switch so it functions nornmally?
3.) whats the deal with the headlights?
Thanx in advance
Geoff
Old Dec 18, 2012 | 06:33 PM
89 iroc convert's Avatar
Car: 1989 iroc convertible
Engine: 305 tpi
Transmission: 700 r4
Re: Steering Column Woes
u can get to them it is rough u almost need a thinwall #8 reverse torx when i did mine i got the socket at autozone and ground it down on a bench grinder they have several very good threads on here a-1 auto has a good u tube video gl
Old Dec 18, 2012 | 06:38 PM
Veaceonee's Avatar
do you have to drop the column? or can it stay bolted up?
Old Dec 19, 2012 | 02:33 AM
Engine: 305 tpi
U dont have to drop the column to tighten the bolts up. But i found if your going to change any switches the require fishing a new wire it easier to take off the brace that holds it in place ,but its simple it should have 2 bolts to the car and 4 into the colunm . i brought my laptop and sat it in the passinger seat and kept rewinding the A-1 auto video . best of luck it is a simple fix ( i spent more time trying to find the pin puller than doin the repair)
Old Dec 19, 2012 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps you'll find something useful in the following sticky:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Dec 20, 2012 | 04:44 PM
Veaceonee's Avatar
thanks for the advice, will check it out this weekend.
Old Dec 26, 2012 | 04:23 AM
Veaceonee's Avatar
Havent gotten around to actually fixing it yet due to work, but something interested has come up. Whenever I go around a corner to sharply the horn honks. Its kinda funny, people look at me weird, but I want to fix it. Ideas as to why it is doing this?
Old Dec 26, 2012 | 12:15 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
the horn switch is connected to the steering wheel with couple moving parts "plstic horn switch,the spring beneath swith, metal pole that provides electrical connection to plastic horn switch, to conclude with horn button wiring" so you might have a short somewhere when turning the wheel maybe
you can keep steering column on when take steering wheel apart
did you take off the plastic cover or did it fall off for turn signals/highbeam switch "directly behind turn signal switch on left side of steering column ? while disassembling the steering wheel... the plastic cover holds the highbeam switch in place removing it and switch can fall out place "plastic part that pushs the rod for highbeam" for the turn signal issue.... just trace your elctrical issue starting with the switch... when its apart... steering wheels is pretty easy to fix and take apart as long you got correct tools also check if lightbulbs are good of course
Last edited by Zach/90\irocZ; Dec 26, 2012 at 12:55 PM. Reason: spell correction / grammer
Old Dec 26, 2012 | 12:38 PM
JamesC's Avatar
Originally Posted by Zach/90\irocZ
did you take off the plastic cover for turn signals while disassmnly that plastic cover holds the highbeam switch in place removing it and switch can be out "plastic part that pushs the rod for highbeam turn signal issue just trace your elctrical issue steering wheels is pretty easy to fix and take apart as long you got correct tools
JamesC
Old Dec 26, 2012 | 12:40 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Originally Posted by JamesC
JamesC
what you dont understand?
Last edited by Zach/90\irocZ; Dec 26, 2012 at 12:50 PM. Reason: edit previous post
Old Jan 6, 2013 | 09:55 PM
Veaceonee's Avatar
No amount of screw tightening will fix this. New steering colum time.
Attached Thumbnails Steering Column Woes-2013-01-06_20-22
Old Jan 7, 2013 | 12:40 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
What part is that kinda hard to tell from pic ... Just go to junk yard and find good replacement and if its a little loose tighten it up
Old Jan 7, 2013 | 01:29 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Google 'cascade crew': one of the guys did an AWESOME write up on breaking down the steering column to tighten the tilt bolts. It is VERY educational!
Old Jan 7, 2013 | 08:41 AM
Veaceonee's Avatar
The above picture is the lower housing, where the tilt knuckle is.
Here is a picture of the lower knuckle that is all broken out.
My father, who used to rebuild these colums for a living says he has NEVER seen one broken out like that.
Got a new column, and intermediate shaft since mine is junk, out of a camaro from the junkyard.
Let the fun begin
Attached Thumbnails Steering Column Woes-2013-01-07_07-35
Old Jan 7, 2013 | 09:57 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
to come to think of it ..i had one broke also in my last camaro .. i assume its because how some people break into cars and get the steering to unlock and in the process break it or something its kinda weird ..
shouldnt be too bad to replace just a little fun putting it together
Old Jan 7, 2013 | 03:50 PM
Veaceonee's Avatar
Pulled a colum and Intermediate shaft out of an 82 camaro in the junkyard. Swapped over all the pieces I could(found out the rods are different). works like a champ now. Less than $100 invested.
Old Dec 5, 2021 | 12:42 PM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
looking for some tips on how to get the bolt holes to line up to mount the steering column to fire wall, my column seems to hang a little low, would having another person with me make it simpler, i switched from standard to tilt column
Old Dec 5, 2021 | 05:07 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Install the firewall hardware first,..... then raise the column to the dash housing studs,..... then connect the intermediate shaft.
Old Dec 10, 2021 | 12:45 PM
Car: 1988 FORMULA
tried that an the dash studs would not line up, about 2-3 mm off, will not go foward enough, took firewall bolts out an still wont line up, did before I put firewall bolts in
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
