seat belt trim
Car: 88 GTA Notchback
Axle/Gears: don't know
seat belt trim
The plastic trim around the seat belt where it comes out of the roof has fallen down, and I don't know how to put it back up. I try to slip it back in the slot but it falls back down. what is the secret to keeping them up where they belong?
On a side not, how do I tighten up the seat belt guide on a GTA seat?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: seat belt trim
They should just snap in place in the grooves,most likely the tabs are broken and you need to replace them.As far as the seat belt guide,you have to remove the one screw you see and you'll see their is another one under their, tighten the one underneath then put the screw back and tighten it up.
