87 -91 dash assembly Bird
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
Are 87 and 91 Dash assembly and consoles the same?
Pics anyone? Need to see the difference plz.
Firebird
Firebird
Engine: LS1, LB9, L03
Re: 87 -91 dash assembly Bird
Only difference w/consoles is that 91 automatics will have a shift indicator that moves with the shifter.
In 1991 they changed the location of the switches for the fog lamps, rear defrost, and rear hatch release. Also no subwoofer available in 91, whereas 87s would have a Gain slider next to the other switches if they had this option. 87s had the switch panel on the lower left driver's side dash trim, whereas 91s would have it just above the a/c controls.
You can see the 91 switch panel in the photos of this butchered base model 92 that some moron is trying to list as a GTA on eBay here http://cgi.ebay.com/ebaymotors/1992-...#ht_500wt_1182
You can see the 87 switch panel in the photos of this stupid nice 87 GTA on ebay here http://cgi.ebay.com/ebaymotors/ULTRA...t_64788wt_1167
