Removing gray paint from firebird dash
Old Feb 3, 2013 | 04:41 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I realized that the gray dash support are not molded with the color, but rather painted, unlike other gray plastic parts that are actually gray.
What is the best way to remove the paint (back to black) without melting the plastic?
-- Joe
Old Feb 3, 2013 | 11:25 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Removing gray paint from firebird dash
Acetone,nail polish or rubbing alcohol,they do not create heat like paint remover.
Old Feb 4, 2013 | 06:44 AM
82tarecaro's Avatar
Brake fluid will take it off. It will not harm the plastic. When I needed to strip plastic from a large part I would brush the brake fluid on. It needs to be on there for a day or two and you need to go back every now and then and brush more fluid on.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
