Fuel gauge level
Old Mar 17, 2013 | 02:23 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Fuel gauge level
Hi all,
This is easy question which I feel stupid I don't know the answer.
Is the fuel gauge level suppose to go down to empty when I turn off the car?
Thanks!
Old Mar 17, 2013 | 05:26 PM
C4Vert's Avatar
Re: Fuel gauge level
No. The Owners Manual also covers that
Old Mar 17, 2013 | 08:47 PM
podiatra's Avatar
Engine: 350 swap
Thank! I will visit the manual more often.
Old Apr 28, 2013 | 01:37 AM
David Wade's Avatar
Engine: 5.7L TPI
When the car is off it's an unpowered circuit. The sender in the tank varies signal to the gauge based on the fuel level, but only when power is applied. Since this is an electric gauge, it can't read anything with power removed (accurately). I've had some that stay put while off, and some that drop to E while off, I've even had one that went higher after I shut it off.
Old Apr 28, 2013 | 04:06 PM
podiatra's Avatar
Engine: 350 swap
Thanks!
Old Apr 29, 2013 | 08:53 AM
FinallyGotMyZ's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 305 5.0 L TPI
Transmission: 700 R4
Not to hijack the thread, but is that why my tach needle sometimes drifts up to the 1500 mark after shutting the car down?
Old Apr 30, 2013 | 04:23 AM
David Wade's Avatar
Engine: 5.7L TPI
I would assume this to be true. The one in my car is electrical, so the changing difference in potential as the power is removed would make it behave a little odd. Same with all the gauges in a 3rd Gen. except the cable driven speedo's. As long as they reset when power is applied I think it wouldn't be anything to worry about, unless of course they are inaccurate.
Old May 10, 2013 | 08:39 AM
They do indeed reset, it was just a little weird to see the tach needle climb after the power was shut off. Thanks!
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
