87 bottom seat cushion swap
Old Mar 30, 2013 | 09:43 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Does anyone Know if the seat bottom cushions on an 87 Iroc can be swapped from one side to the other?My drivers side is power.Thanks
Old Apr 7, 2013 | 08:32 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 87 bottom seat cushion swap
On the left side of the passenger side of the seat there is a "pivit" bolt and on the other side there is a hinge bolted to the seat. In order to swap the passenger side seat bottom to the drivers side you need to remove the pivit bolt clip from the left side of the seat frame and install it on the right side of the frame. That way once you re-install the pivit bolt it's got something to screw into. The easiest way to access that clip ( much like a large body panel clip ) without making more holes in the fabric is to partially remove the seat fabric, move the clip to the other side of the frame, and re-install the fabric.
The only real disadvantage to this is that the right side of the drivers seat will still have the 2 holes in it where the hinge used to be installed when the seat bottom was originally on the pass side. But - at least it's just about never visible as that part of the seat would be mostly hidden by the console.
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
