HELP
Old Apr 14, 2013 | 05:00 PM
USA1 82Camaro's Avatar
Car: 1982 camaro berlinetta
Engine: 5.0
HELP
i know this is probably the dumbest question on here but i need to know can i use my stock tachometer that works and install a aftermarket one and they will both work thanks for the help!!
Old Apr 14, 2013 | 05:16 PM
Engine: 5.0
Re: HELP
it is carberated also
Old Apr 15, 2013 | 12:55 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: HELP
I dont see why not as i have a rpm on the dash and a digital one on the pillar. No real difference between carb and fuel injected as the signal has to come from somewhere
Old Apr 15, 2013 | 01:30 PM
Engine: 5.0
Re: HELP
how do i hook it up then
Old Apr 15, 2013 | 03:09 PM
6SIX6's Avatar
Car: 89 IROC
Re: HELP
I hooked mine up to the tach signal wire behind the cluster as i ran all aftmarket gauges but I dont see why you cant do the same. Plus if you do that you can run the wire behind the dash to the spot you want it at
