door handle plates
Old May 12, 2013 | 04:23 AM
tyler.richards1's Avatar
Car: 1989 Pontiac firebird
Engine: 2.8 V6
Transmission: 5 speed manual
door handle plates
ok so here is my problem i am shaving my door handles interior and exterior would anybody know how i can make my handle plate one solid piece or should i look int loke adding a light mod to fill in that hole or maybe both? i really need help with this i want my interior to look as clean as possible
Old May 12, 2013 | 07:06 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Re: door handle plates
BUt how are you gonna open the door?
Old May 12, 2013 | 08:29 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Couldn't you make the carpeted panels without the cutouts? My thinking may be off,
Also how do you plan on opening the doors?
Old May 12, 2013 | 09:45 PM
Engine: 2.8 V6
i am going to be installing two buttons below the shifting leaver above the center glove box that are going to activate the solenoids and pop the doors
Old May 17, 2013 | 06:21 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I shaved my doors...outside is easy...just take handel out and lock out and weld over with some metal. ...I'm leaving the inside door handle. ..but im taking the locks completely out...I too will have door poppers...but no need for locks if there is no door handels on the outside....I wouldn't take the inside door handles out...also with remote door poppers I'll have the windows on a remote. ..and the rear hatch...
Attached Thumbnails door handle plates-imag0519.jpg   door handle plates-imag0520.jpg   door handle plates-imag0522.jpg
Old May 17, 2013 | 08:16 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
http://www.kindigit.com/store.php
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
