IROC Driver seat loose
Old May 22, 2013 | 11:54 AM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
The back part of my 86 Camaro IROC seat seems to be loose. It is the electronic seat and the electronics seem to work with no problem but the back part of my seat is always in a slight reclined position. Not only that I don't have to use the lever to push forward to get in the back. Is their a place to tighten or reattach the back of the seat?
Old May 22, 2013 | 05:06 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: IROC Driver seat loose
The best thing to do is remove the four bolts that secure the seat to the floor and then do an inspection. I ran into a similar problem and later found a solution. I created a thread for it too. Hope it helps!
https://www.thirdgen.org/forums/inte...issue-4th.html
1992 Trans Am
May 10, 2023 07:19 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
Mister_Johnny99
Aug 14, 2015 12:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
scottmoyer
Aug 9, 2015 10:18 PM
