Ignition hellllllp :(
Old Jun 2, 2013 | 04:48 PM
DancesWithDeath's Avatar
Car: 1991 rs camaro
My key wont come back to stationary position to pull the key out.
I guess it's time to take the ignition out. I can't figuire out how. I've pulled the steering wheel. Nothing. Car is a 91 rs 305 auto.
Old Jun 2, 2013 | 06:07 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Ignition hellllllp :(
I'm confused as to exactly what you are asking. I had the exact same situation with the key getting stuck and not returning to the off position (mine actually got stuck with the car running-had to pull the fuel pump fuse to shut off the car).
As for removing the cylinder, follow the steps in the following link until you get to the point you need to get to and then you can either continue on while you're in there or button it back up and enjoy your new cylinder.
https://www.thirdgen.org/forums/susp...-steering.html
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
