Found the heart of the Iroc!
Old Jun 4, 2013 | 11:19 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Tore apart the cluster to replace a speedo cable and noticed this odd shaped cutout!
There is no reason to have this cutout shaped the way it is!
Anyone else ever noticed this?
Old Jun 5, 2013 | 12:04 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Found the heart of the Iroc!
When you re-install the cluster - if you haven't already - note that the malee connectors can be removed from the housing. Not removed from the wires, but it can be pulled out and turned. Make sure it is seated the same way it is shown as in your photo. This way, the female portion - on the gauge cluster - can receive the male portion once you apply gentle pressure. Do that first, then do the speedometer connection (which is a bitch).
Old Jun 6, 2013 | 10:52 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Custom Deluxe!
Old Jun 6, 2013 | 11:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Looks like a factory carrier to me. Here's mine...unmolested.
Old Jun 14, 2013 | 05:59 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I just took my cluster out of my 89 iroc for some repairs and I have the heart shape cut out. It is a factory thing. If you look at the back of the cluster, you will see some light bulb sockets in the same area that would hit the dash panel if the cut out wasn't there. Its for clearance for the light bulb sockets.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
bjpotter
Aug 12, 2015 06:06 PM
mustangman65_79
Aug 11, 2015 03:17 PM
antares57
Aug 6, 2015 07:47 AM
