some dash gauges dont work help!!!!
Old Jun 7, 2013 | 05:25 PM
89whiters's Avatar
hi everyone new member to this site.im working on my 89 Camaro rs & I got everything else done but the dash.thecollant temp,oil pressure,fuel gauge don't work .I turn the key on & they twitch,im not sure whats up!!!trying to figure out the two plugs in the back of the instrument cluster to try & fix or wire them up direct.some help would be appreciated.kinda intimmitated by all the wires together.
thanx
Old Jun 10, 2013 | 03:16 AM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
Re: some dash gauges dont work help!!!!
thanx
I doubt this is your solution, but with my gauges there is a wiring harness with clips on both sides behind the tachometer and if that thing isn't fully seated and clipped in, the gauges on the left ( fuel, battery, tach, temp, and oil) will twitch at first turn of the ignition and whenever you press a little on the cluster shell and plastic cover. I swapped a speedo and disconnected that harness on accident, spent a good 20 mins in panic checking fuses and wires before I realized it was the right side not clipped all the way. Good luck!!
Old Jun 14, 2013 | 03:55 AM
89whiters's Avatar
thanx ill give it a try.i hope thatis it
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
marcusaw
Aug 10, 2015 08:13 AM
