Can you repair a power mirror switch
Old Jun 13, 2013 | 02:25 PM
v vet 1967's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
The power mirror switch only works the mirrors up and down and not side to side. Has anyone else had this problem? Can this switch be repaired? One more question. How do I remove this switch without breaking the plastic housing? Do you pry it out or need to remove part of the console?
thanks
Old Jun 17, 2013 | 09:50 PM
Gus_Mahn's Avatar
Re: Can you repair a power mirror switch
Usually the switches just pop in. Most of the time it's just dirty contacts causing the issue. The switches press together, and have tabs holding thing together. Disassemble, clean the contacts with an eraser (ala slot cars), and reassemble the switch.
Old Jun 18, 2013 | 10:00 AM
fyrebird68's Avatar
The model railroad hobby uses an eraser that has a mild abrasive embedded in it. Great for cleaning contacts.
Attached Thumbnails Can you repair a power mirror switch-mhmmyih_4nnxepqk9d7urlw.jpg
Old Jun 19, 2013 | 06:42 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
You need to remove the console to release the tabs from the back side.
The mirror switches are junk. Doubtful you will be able to repair it. There are replacements available but they will fail too. I would replace it with a switch from a newer car, almost anything is better.
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
overdriv
Aug 20, 2015 03:52 PM
