Grant 870 steering wheel change
Old Jun 21, 2013 | 07:39 PM
Seanphelps321's Avatar
Car: 1992 Firebird
Engine: 3.1L(swapping in 385)
Transmission: Looking for T56
Axle/Gears: Looking for 3.73 posi
I've always wanted to replace my airbag wheel for something that looks better. I'm looking into the Grant 870 wheel found here.
What installation kit should I go for? Grant doesn't offer them for the airbag cars so I'm not real sure.
EDIT: Found it cheaper at... Summit. Like always. LINK
Old Jun 21, 2013 | 08:15 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Grant 870 steering wheel change
You need the install kit for an 82-89 camaro or firebird. It will fit with a little bit of trimming of the cover plate in the kit. Lots of people here have done it, myself included.
Old Jun 21, 2013 | 09:28 PM
Car: 1992 Firebird
Ok. I read on some guys' posts about how they've trimmed part of the steering column with a dremel. Makes more sense to trim the piece in the kit.
Is it the 3196 kit?
Old Jun 21, 2013 | 11:20 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Is it the 3196 kit?
Definitely trim the piece in the kit, not your column. I believe that is the right part number. I did mine 5 years ago, so I'm not 100% sure.
Old Jun 22, 2013 | 09:58 AM
Car: 1992 Firebird
The Grant 870 is 13 3/4". I think the stock wheel is something slightly over 14". As someone that has one of these, would you say the difference in steering is minimal or noticeable?
Also, I don't want the GT Grant symbol on my horn, but the only option that I've seen to change it for our cars is the blank or Pontiac symbol buttons. Is there anywhere that offers a custom Firebird symbol? If not, do you think a symbol from the center caps or the 82-89 wheel would be the right size to fabricate it in?
Old Jun 24, 2013 | 07:27 PM
Car: 1992 Firebird
Bump, do I have any options other than blank/Pontiac symbol for horn caps for this wheel? Maybe a horn cap from an 82 steering wheel will fit?
Old Jun 24, 2013 | 07:53 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
If you have power steering you shouldn't notice a difference in steering effort. If you've got manual steering however, it's noticeable.
As for the center cap, I don't think the wheel cap emblems will fit. I have a blank center cap on my wheel and the center is dished and only about 1.5" in diameter. I'd have to measure to be sure. I just painted mine the same color as the body. Try checking in eBay, there are all kinds of emblems and center caps on there, you might be able to find something that fits.
I've also seen a firebird cap before, but can't remember where.
Old Jun 24, 2013 | 08:42 PM
Car: 1992 Firebird
My original plan was to get an early 80s steering wheel to put on but the prices are crazy for one that is worth it. I like the way the 870 looks. I saw many people got the challenger with 4 spoke. Are there other Grants that people were more successful in putting a firebird emblem on?
Old Jun 24, 2013 | 09:12 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
You could try looking for a 2nd gen firebird horn button. I believe they had the firebird on them and you could cut it off and mount it on your wheel.
Old Jun 25, 2013 | 11:08 AM
Car: 1992 Firebird
That sounds like a good idea. Do you know the diameter of the symbol on the challenger series wheel?
Old Jun 25, 2013 | 01:13 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Not off the top of my head, no. I can measure mine later tonight and let you know.
Old Jun 25, 2013 | 01:44 PM
Car: 1992 Firebird
That would be awesome. I'll probably have to do some fab work to put the symbol on the horn button. Thanks in advance!
Old Jun 25, 2013 | 07:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Measured the horn button. The center recessed section is about 1.5" in diameter, the entire face is about 2.5" in diameter.
Old Jun 25, 2013 | 07:18 PM
Car: 1992 Firebird
Ok. So the symbol itself is 1.5" and the whole button is 2.5"?
Old Jun 25, 2013 | 07:23 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
The whole face of the button is 2.5". The sides flare out from front to back, so measuring from the back side it's probably closer to 3"
Old Jun 25, 2013 | 07:26 PM
Car: 1992 Firebird
Ok. This is what I'm looking at right now:
http://www.ebay.com/itm/1970-1981-TR...72a654&vxp=mtr
Hopefully if anything this is a tad BIGGER and I'll be able to shave it down to size. Maybe it'll be the same size though. Waiting on an email. Unless anyone has the answer to that.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
