Shifter spring aka Lil PIA!
Old Jul 11, 2013 | 11:07 PM
KN1GHT's Avatar
Car: 1989 TA
Engine: 350tpi
Axle/Gears: 3.73 posi
My T shape auto shifter has a spring at the bottom to keep the plastic rod in the shifter tube. The spring hooks onto the J shaped piece of metal that fits into the bottom of the tube so that the car locks into P R or D unless you use the brake....basically keeps you from shifting into a gear you not enter if you bump the shifter....know what I'm talking about?
Where does the other end of that print connect!?! It instantly ones unhooked a couple times a year from the places I have hooked it to.....driving me bananas! Where should it be hooked to!?!
Also, my car suddenly leant o right into Park when I shift it back there...I have o hold it forward so I can her it click otherwise the dang thing will keep rolling....what's with that!?!
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
jer4251
Sep 27, 2015 09:52 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
MarineIROC
Southern California Area
Sep 16, 2015 05:40 PM
armybyrd
Sep 16, 2015 10:03 AM
