Ac hvac vacuum?
Old Jul 26, 2013 | 12:00 PM
bison999's Avatar
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
Ac hvac vacuum?
so i just got the little climate control running on my car. Blower motor works fine, just when it engages i only have defrost blowing under all settings, anyone have this problem or any suggestions? ive followed vacuum lines, and maybe have it open but not sure what would help. thanks everyone!!!
Old Jul 26, 2013 | 02:17 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Ac hvac vacuum?
When the car is running, is there a constant hissing sound that comes from behind the levers for the HVAC controls?
Old Jul 26, 2013 | 02:25 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Re: Ac hvac vacuum?
If there is a constant hissing, this may be the answer. It worked for me.
https://www.thirdgen.org/forums/inte...anent-fix.html
Old Jul 26, 2013 | 03:03 PM
W.E.G.'s Avatar
Engine: V6 2.8
Re: Ac hvac vacuum?
Yep, that's the most likely fix for the only-blows-through-defrost-vents.
Driver will probably also notice better engine performance when that vacuum leak is eliminated.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
Eric-86sc
Sep 28, 2015 11:37 AM
