Interior pieces
Car: 88 sport coupe
Engine: L03 305
Interior pieces
Alright guys I need some guidance
I can't for the life of me, find the black plastic piece that surrounds the door handle/lock/mirror adj etc
Also my dash is SUPER cracked is there any good way to fix this?
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Interior pieces
Not sure who sells, but there are many great sellers on this site, just go to classifieds. I find most of my needs met at pick and pull, craigslist, & here on classifieds. Good luck
Car: 89 Iroc Convertible
Re: Interior pieces
I have a pair of the black door trim...20 dollars shipped in the USA
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Interior pieces
If your armrests are the early style (with a 'stripe') you'll need bezels from an 82-89. If your arm rests are the later style (no stripe) than only 90-92 door bezels will work poperly.
The early armrests used a "spacer" at the upper bolt, but the later armrests didn't and the bezel hole for the upper arm rest bolt is larger on the 90-92 door bezels to account for this design change.
Car: 88 sport coupe
Engine: L03 305
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Thomas
Oct 3, 2015 05:34 PM
