Door Panels off -- Make the Power Locks Work?
Old Aug 26, 2013 | 02:01 PM
72SSboy's Avatar
Car: 1988 IROC-Z
Hey there -- I have my door panels off and the door lock motors sound great when I click lock and/or unlock. But, as usual, the metal bars do not travel the entire path they need to to actually lock and unlock the doors. Is there a trick to fixing this?
The entire thread on my interior project is here: https://www.thirdgen.org/forums/inte...lots-pics.html
any and all advice is welcomed.
thx!
j
Old Aug 26, 2013 | 06:24 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
Re: Door Panels off -- Make the Power Locks Work?
I had the same problem. spray all the moving parts with wd 40 or PB blaster. Then clean it up the best you can. Apply some white lithium grease to every moving part. press the unlock/lock button several times and they should work. I was about to replace my actuators till I tried that. Worked out great just needed a good cleaning and lube. Let me know how it works out.
Old Aug 26, 2013 | 06:30 PM
72SSboy's Avatar
Car: 1988 IROC-Z
thanks a million! Will give it a shot.
j
Old Aug 27, 2013 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Since you're in the door anyway, you might consider some of the following fixes:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
z28addict8490
Aug 7, 2015 08:48 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
