shift indicator plate replacement on my GTA
Old Sep 22, 2013 | 10:30 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
OK, so I have a new manual shift plate in my GTA now and need to replace it with a 6 speed version for my T56. Thing is, it appears to be glued in (rather well at that) and I realllly don't feel like breaking it if there is an easy way to remove it. How have you guys been doing this?
You'd think they would offer them now with the 6speed plates installed, not just the 5 speed plates...
Old Dec 4, 2013 | 08:54 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: shift indicator plate replacement on my GTA
I know I am digging this up, but I haven't been brave enough to try and take mine apart since my plate is mint
Were you able to get yours apart?????
Old Jun 2, 2014 | 01:20 PM
WTR388's Avatar
Car: 87 Trans Am
I'm gonna bump this... I am too chicken to mess up my brand new pieces.
Old Aug 17, 2014 | 10:29 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Same boat-new Hawks shift plate and 6-speed indicator...not looking to ruin the shift plate!
Old Aug 18, 2014 | 02:43 PM
Pocket's Avatar
Car: 91 Trans Am
Its glued in, had one fall apart on me a few years ago. Youll likely break it taking it apart
Im running an automatic shift plate with the range indicator painted black. Gear pattern is on the **** itself. Shifter range is much tighter than T5, so the small opening for the auto boot is plenty
Old Aug 27, 2014 | 02:49 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
I unbolted the shifter boot from the bottom, removed it, then carefully ran a razor knife around perimeter of the little box that is glued to the shifter plate and it popped right off and the indicator lense came right out (lense isn't glued, just fits into hole on shifter plate and held there by the light box once you glue it back into place). Put my new 6-speed indicator in and used some model glue to hold box in place. Definitely suggest removing the shifter boot first as the light box is clamped between that and the plate. Otherwise, no biggie.
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
mizz0313
Aug 12, 2015 06:45 AM
marcusaw
Aug 10, 2015 08:13 AM
