Rear defrost
Old Sep 27, 2013 | 10:07 PM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Rear defrost
How hard is it to add rear defrost ?
Old Sep 28, 2013 | 09:19 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Rear defrost
Very easy, replace the rear glass with a defroster one and wire it in.
I'm being a bit flip because I think you meant how to add defroster elements to the glass. Pretty much impossible for the home mechanic, certainly more trouble than its worth.
if you swap the glass, I think I remember from the non-defroster model i stripped that most of the wiring harness is there, you will have to run the heavier guage wire to the rear from the fuse panel and install a switch. Iirc the harness is there behind the dash.
You should know that most cars came with defrost and that many people are looking for non defrost glass for show cars or cars with tinted rear glass. You can prob get some decent money for the non defrost glass.
Old Sep 30, 2013 | 11:48 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: Rear defrost
I have a rear hatch w/ defrost available if you're interested. I could probably dig up some wiring too. I'm 35 miles NW of Savannah...I don't think that's too far from you. PM me if interested.
-Tom
Old Oct 12, 2014 | 07:56 PM
tb3's Avatar
tb3
Car: 1989 Firebird Base
Engine: 2.8 V6
Axle/Gears: stock
Re: Rear defrost
besides the switch, wiring to the rear glass, and the rear hatch w/defrost.... what else is needed?
I have a 1989 firebird. is there also a timer or relay to add?
Old Oct 12, 2014 | 11:35 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Rear defrost
Find details here:
https://www.thirdgen.org/forums/elec...defroster.html
Good luck !
Old Oct 13, 2014 | 11:52 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Rear defrost
The timer is built into the switch. I added all the wiring to install rear defrost on my car minus a replacement hatch glass with the heating element on it. Been dragging my feet on it since that hatch is a heavy sucker to remove without help from a friend.
Old Oct 13, 2014 | 12:09 PM
tb3's Avatar
tb3
Engine: 2.8 V6
Axle/Gears: stock
Re: Rear defrost
Thank you sir!
hectre13
Dec 11, 2023 08:14 AM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
