Illuminated Door Sills
Old Oct 7, 2013 | 01:13 AM
WestOzGTA's Avatar
Car: 87 Trans Am GTA
A little project I finally finished off on the weekend...
I made these from 40x3mm aluminium strips, backlit with electroluminescent panels (eBay!). Initially I was intending to cut out the checkered section of the original plastic door sills to make a frame into which I would set the panels. However I decided that it would be too hard to get perfectly straight lines, and the sills are a bit warped as well since the surface they sit on curves up slightly at each end. Plus when I put the panels on top and the holes lined up perfectly I thought they looked so good that I just wouldn't bother with the extra stuffing around.
The only modification I needed to make to the plastic sills was to cut a slot for the EL panels to go through, and I also needed to shave down the "frame" either side of the "body by Fisher" logo since it bulges upwards slightly.
With the added thickness there is just enough room for the doors to close... in fact I get a slight rub on the left hand side at the door jamb end, and it took a tiny bit of paint off the underside of the door, but ahh who cares.
Attached Thumbnails Illuminated Door Sills-20131006_160325.jpg   Illuminated Door Sills-20131006_202620.jpg   Illuminated Door Sills-20131006_202710.jpg
Old Oct 7, 2013 | 05:14 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Illuminated Door Sills
Good job!!
Old Oct 7, 2013 | 09:45 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Nice, I would like to do something similar.
Old Oct 7, 2013 | 11:42 AM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
so you brought it off ebay and slap it on top? Pretty sick, so much better than the plastic stuff lol
Old Oct 7, 2013 | 12:04 PM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
looks great.
Old Oct 7, 2013 | 12:07 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Looks cool, I had to do a double take- not accustomed to seeing pedals on that side lol.
Old Oct 7, 2013 | 01:55 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Those really look good! Nice job.
Old Oct 7, 2013 | 11:24 PM
WestOzGTA's Avatar
I bought the electroluminscent panels/strips from eBay... they are sandwiched between the original plastic and the aluminium panels (which I made).
Old Oct 8, 2013 | 12:02 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
That came out really nice!
Old Oct 8, 2013 | 01:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Looks very nice!
I also like the sheepskin seat covers.
Old Oct 8, 2013 | 02:23 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ill take a set with red or orange illumination please. Or maybe white to match my possible new gauge combo...
Those look great!
J.
Old Oct 10, 2013 | 11:43 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
what would you charge to make me a set?
Old Oct 10, 2013 | 11:47 PM
WestOzGTA's Avatar
Haha... lots... it took about 2h per side, and I don't really wanna go through it again!
Advice is free though... which is charging for what it's worth
Old Oct 12, 2013 | 02:03 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
I've been pondering this since we got my wife's cube. Her door sills light up "Cube" in blue and I thought it was pretty cool looking. I have a different idea how to do this, mostly because I don't have access to a water jet or whatever you used to cut out your logo. If I get it together I'll post it up.
Old Oct 13, 2013 | 08:47 AM
Car: 86 Trans AM
How did you make the actual metal cover with Trans AM in it. Thats the part that I think would need to be produced. Everyone could get the illumination panel and do the fitting. But it looks like you got them laser cut or water jet cut?
How bright are they at night? Can you notice them at all in the daylight?
J.
Old Oct 13, 2013 | 04:54 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Those look KILLER
How did you get the Trans Am cut into the alum. strip?
Old Oct 13, 2013 | 08:39 PM
WestOzGTA's Avatar
Thanks for the compliment, but no... I wish! That would have saved a bit of time. I did them by hand, with a rotary tool (Dremel copy). I printed out the logo as a mirror image and then stuck the strip of paper to the back of the aluminium using spray glue. Then I painstakingly cut out the design...
First up I tried using the Dremel tungsten carbide cutting bit, however these are designed for hard metals only, so it just got gummed up... very slow going, and I almost gave up at the beginning. In the end I found that a drill bit worked best. Using a 2mm drill bit I drilled holes very close together around the perimeter of the design, then cut between them, again using the drill bit. There was a technique I developed which is hard to describe but kinda like using the drill bit as a router to gradually take out more depth. Actually, a router bit probably would have made it easier...
I did use the tungsten carbide cutting bit as well for less agressive fine smoothing. Then, where I could, I used a very thin flat file and triangular file to get nicer lines and corners.
The EL panels produce more of a soft glow than illumination, as can be seen in the second pic, which was taken without flash. It's hard to show in pics because without flash you don't see everything else too well and with flash everything else is a bit bright. The third pic was taken at the same time, with flash.
The first pic is daylight... you can't really notice the backlight very much at all unless the car is in a shaded area. With the first pic there would only be a subtle difference with them disconnected. With them off in a shaded area they are a darker blue, but in sunlight they look lighter anyway if that makes sense.
Old Oct 13, 2013 | 11:49 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
That is one cool mod. I'm thinking I'm going to have to borrow this one lol!
Old Oct 14, 2013 | 12:31 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Where did you buy the aluminum strips from?
Old Oct 14, 2013 | 01:31 AM
WestOzGTA's Avatar
Just the local hardware store (Bunnings here in Australia)... bought a 3m length and cut it in half in the carpark so I could get it home
Old Oct 14, 2013 | 02:17 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Awesome job dude. I've had it in the back of my head for awhile to do exactly this. 5th gen Camaros have these as an option.
Old Oct 14, 2013 | 03:31 AM
Car: 1990 Camaro RS
Engine: L31
Wow, way lower tech than they appear. Excellent work! I have the components ordered for my secret way of doing it and the lexan already cut... perhaps I've said too much.
Old Oct 14, 2013 | 07:12 AM
Da Spudro's Avatar
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
Cool. I've been wondering how to go about doing this to my car for while. Think I'll probably use a slightly different approach though. I've used EL stuff bfore and it doesn't hold up to heat very well, so i'll probably make the alluminum sill covers, cutting out Camaro Z28 in them, use a peice of fogged lexan and mount a 16 color changing led strip under them so i have the option of changing colors like the mustangs... Not sure if the new camaros do it or not...
Thanks for the idea, and the basis for me to go from. Looks great by the way - hope the EL holds up better for you then it has for me
Old Oct 14, 2013 | 10:16 PM
WestOzGTA's Avatar
Thanks. Me too... I hadn't heard or thought about any problems with heat so hopefully they'll be fine.
My first idea was to fill the cutout with something translucent white (which I tried, using polymorph pellets) and backlight with LEDs. However I found that I didn't get enough diffusion of the light and still had bright spots. Either the LEDs need to be further away, or I'd have needed at least 30 per side. I googled for other options and found the EL stuff, the added benefit being that it's a lot thinner than LEDs.
If you can get LEDs to work and give nice diffused backlighting then the colour changing would be really nice.
Old Oct 15, 2013 | 08:32 PM
Car: 86 Trans AM
Wow Im impressed! Thats quite a bit of patience and work to make that lettering! Ive used those carbide bits on alum before...its frustrating. Actually, using just about anything on alum can be frustrating haha. Way to stick it out and make your vision a reality!
Thanks for the info! Maybe a fun thing to play around with some winter.
Justin
Old Oct 16, 2013 | 11:01 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
They look excellent. A very upscale touch.
What did you wire the EL panels into? Are they switched to come on when the door is open?
Old Oct 18, 2013 | 01:19 AM
WestOzGTA's Avatar
Yep - they each came supplied with a small 12v DC to 110v AC (I think) inverter... these are just wired into the courtesy lights that are by your feet.
Old Oct 19, 2013 | 05:49 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
going to see what i can do using a led strip with multi color so far started cutting out the lettering ill post up pics later if anyones interested
Old Oct 19, 2013 | 09:32 PM
Car: '87 Camaro
Please do post pics!
Old Oct 20, 2013 | 02:05 PM
Richboll's Avatar
Engine: 305 TBI
Yep, I'd like to see some pics also. This looks like a good mod that can be easily reversed if needed.
Old Oct 20, 2013 | 02:31 PM
Car: '87 Camaro
I have searched ELtape & there is alot of stuff out there!
Colors--
White, Red, Yellow, Blue, Aqua,Green.
Length & width vary.
A couple sites say you can trim with scissors.
Depending what you want, invertor & splitters available or may come with as a kit.
Old Oct 21, 2013 | 01:43 AM
Chubb's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 305 Carb
Transmission: 7004
That is cool and innovative!!!
Old Oct 21, 2013 | 07:13 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Crap design trying to figure something else out with them
Old Oct 21, 2013 | 07:34 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
Maybe you could cover those LED's with chrome mesh, might defract the light and cover the high spots, and give it an industrial look in the day time as well, to the OP this is a cool yet subtle touch, definitely has my gears turnin
Old Oct 21, 2013 | 09:18 PM
Car: '87 Camaro
How far are the lights from the sill?
What did you cover with?
Old Oct 21, 2013 | 10:43 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Maybe a 1/8 inch between the sill and the led's
Sidwys if I did do mesh id probably do black to blend it all together and not to take away from op's great idea and very nice piece
Old Jan 13, 2014 | 03:14 AM
Car: 1990 Camaro RS
Engine: L31
Updating where I finally got to on this. I have my red EL ribbon and the driver's side ready to wire in and install.
Here's a teaser:
Old Jan 14, 2014 | 12:03 AM
Car: 1990 Camaro RS
Engine: L31
Lit up with a 9v, it's not pink in person.
Old Jan 14, 2014 | 05:26 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
That looks awsome man
Old Jan 14, 2014 | 07:21 AM
Richboll's Avatar
Engine: 305 TBI
Nice job. Did you machine the letters out? That looks good enough to sell.
Old Jan 14, 2014 | 01:47 PM
Car: 1990 Camaro RS
Engine: L31
It's actually a piece of tinted lexan that I put a sticker over and painted with satin paint.
Old Jan 16, 2014 | 08:20 AM
  #42
Car: 86 Trans AM
That looks fantastic!
Old Jan 16, 2014 | 08:12 PM
  #43
WestOzGTA's Avatar
Great job!
Old Jan 19, 2014 | 06:12 PM
  #44
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Are these for sale ?
Old Jan 23, 2014 | 08:00 PM
  #45
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
I woukd totally buy a set of these
Old Jan 24, 2014 | 12:05 AM
  #46
Car: 1990 Camaro RS
Engine: L31
I think WestOzGTA's are a more durable design. If mine get scratched then red light will leak through where it was scratched.
Old Jan 25, 2014 | 07:10 PM
  #47
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
Did you put the paint on the top or bottom? If you painted the bottom it shouldn't get scratched easily.
And I would totally buy a set or ship mine to you to modify if you were decide to start selling them.
EDIT:Although thinking about it for a minute, unless the lexan was really thin, the letters probably wouldn't be all that sharp if it was on the bottom maybe. IDK, I'll have to find some lexan & experiment.
Old Jan 26, 2014 | 09:10 PM
  #48
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Im in for a set
Old Feb 20, 2014 | 04:04 AM
  #49
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
great work, I have been thinking about the same setup so it's good to see how they look
Old Mar 4, 2014 | 09:39 AM
  #50
88gtadan's Avatar
Car: 1988 Pontiac gta
Engine: 5.7 tpi
Axle/Gears: Borg Warner 3.27
that is insanely awesome
very nice job
