Sem paint Color
Old Oct 14, 2013 | 09:33 AM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
Sem paint Color
I'm not sure if this has already answered. I did a search, but came up with nothing helpful. I have a 1987 Camaro Sport Coupe with the grey deluxe interior. I have a copy of the original invoice and it says AR9 gray cust cloth. My rear panels are faded very badly, but not broken or brittle. I would like to just repaint them to the stock grey, but I am not sure what color SEM has to match. Does anybody know what color I would need?
Old Oct 14, 2013 | 10:00 AM
82tarecaro's Avatar
Re: Sem paint Color
The SEM paint colors in the spray can come close but are not a perfect match. You can get a custom mixed color from a paint shop that has the SEM product line.
Old Oct 14, 2013 | 10:47 AM
z28v8's Avatar
Car: 1987 IROC-Z
Re: Sem paint Color
Originally Posted by 82tarecaro
...You can get a custom mixed color from a paint shop that has the SEM product line.
I've done this a few times for other cars. Clean the plastic well, then use SEM's plastic prep, then spray the custom mixed dye. If you don't have your own spray gun, get yourself a 'Preval Model 267' disposable sprayer... they work surprisingly well and are inexpensive.
Jeff ~
Old Oct 14, 2013 | 10:58 AM
87cam305's Avatar
Engine: 305 (LG4)
Re: Sem paint Color
Thanks. Do I give the shop the AR9 code, or is there another code for the color. I have done interior paint before to. I had a 95 Dodge Intrepid that i repainted the lower half of the dash. and some other pieces with the SEM paint. I had to get a custom mix for that as well.
Old Oct 14, 2013 | 12:19 PM
z28v8's Avatar
Car: 1987 IROC-Z
Re: Sem paint Color
Originally Posted by 87cam305
...Do I give the shop the AR9 code...
AR9 isn't a paint code... it's more of a description.
You'll likely have to just give them a piece of plastic trim and have them mix/match the dye to that.
If you're lucky, someone else reading this has already done it and can provide the paint/dye code to make it easier...
Old Oct 14, 2013 | 01:07 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Sem paint Color
AR9 only describes the type of seat (base), not the color. 82C is going to be your interior color code.
SEM currently does not make anything in an aerosol can to match code 82C, which I think is ridiculous since it was in probably 50% of F-Bodies made from 1984-92. Your SEM supplier can probably custom match something close in a quart can that will have to be applied with a spray gun.
If anyone knows of an out-of-the-can color that works, I would like to know as well. I don't have access to a spray gun, and need to redo the majority of my interior panels also.
Old Oct 14, 2013 | 04:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Sem paint Color
Hawk312,82tarecaro and I have ordered our interior plastic paints from BAPS,they do a very good job on matching up the colors.Just call them and give them the info.and they'll quote you a price.You may not like the price(not cheap)but it's a very good match.
BAPS AUTO PAINTS&SUPPLIES
2770 Lewisberry rd.
York,Pa,17404
717-767-6544
Old Oct 14, 2013 | 06:01 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Sem paint Color
You could always change the interior color and use the SEM Black
Old Oct 14, 2013 | 06:52 PM
kymmee's Avatar
Re: Sem paint Color
I have also used BAPS thru 82tarecaro as a referral. Got a few cans custom mixed when restoring the MSE interior. Quality paint and a great business to deal with.
angel2794
Sep 8, 2015 06:22 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
