Chrome ignition lock piece
Old Oct 12, 2013 | 11:59 PM
jpach1990's Avatar
Car: 1984 Trans Am Recaro
Engine: 5.0L V8
does anyone know the name of that metal piece on the the ignition where your key goes in and theres 2 metal tabs and it turns with the key one of the tabs on mine broke off and im trying to find another one
Old Oct 13, 2013 | 12:22 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: Chrome ignition lock piece
That is called the ignition switch. You will get a new key when you buy a new one at the parts store. It is available in chrome and black.
Old Oct 13, 2013 | 12:33 AM
jpach1990's Avatar
Engine: 5.0L V8
would i be able to use my old key with it
Old Oct 13, 2013 | 01:14 AM
Car: 1990 Camaro RS
Engine: L31
No, it will come with two new keys. You will have to pull down the steering column a little to replace it. It is a 10 minute job if you know what you are doing. You will need a steering wheel puller, a lock plate compressor, two picks, a phillips screw driver and I believe it is a T15 torx driver.
Old Oct 14, 2013 | 09:22 AM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
It is not called the ignition switch. It is the ignition lock cylinder. the switch is mounted on top of the column under the dash
Old Oct 15, 2013 | 01:07 AM
Car: 1990 Camaro RS
Engine: L31
You are correct. Ignition switch is often used as a synonym for it, but is incorrect. Great correction.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
