Replace Front Seat Belts
Old Oct 16, 2013 | 03:36 PM
buzzmeup's Avatar
Car: 1986 Camaro
Engine: 350-4bbl-Edelbrock Headers
I have a 86 Camaro, How hard is it to replace the front belts, looks like the headliner would have to come down??? Suggestion on after market belts?
Old Oct 16, 2013 | 03:46 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Replace Front Seat Belts
Not hard, just need a "star" bolt socket to remove install. install has always been harder as the bolt can strip easy. If you are taken all of the belts, then you have to remove sail panel & lower headline to upper part of front belts & remove rear seat to get to rear belts. I'm sure U can get em after market/repo/ orig gm, but Ive done well @ junk yard, third gen classifieds or Clist
Old Oct 16, 2013 | 08:13 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
some are still available from gm.i have a new drivers belt.
Old Oct 16, 2013 | 09:46 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
You'll need a Torx bit in the upper 40 range (47 or 49?). The floor install removal is easy. I'd spray a little penetrant first then tap the bit in to make sure it's seated well. Then, remove.
The headliner and sail panels will come out too, possibly more. The plastic color coded trim piece on the ceiling at the belts exit has tabs that are very breakable. Same thing with using penetrant and tapping the bit.
I'm a seat belt wearer all the time, driver or passenger, so I'm going to upgrade to brand new seat belts. These just came out; expensive, but can you put a price on your safety?
http://www.classicindustries.com/198...ts/c97103.html
Old Oct 17, 2013 | 06:38 AM
buzzmeup's Avatar
Car: 1986 Camaro
Spoke with CLASSIC yesterday. I was not sure how the belt fastened down by the seat as they were not using that extractor. The vender stated that a cover comes with the kit to replace the extractor. I use mine ALL the time. Forgot to ask if The short belt comes with the plastic cover, hope so, it will get lost between the console and seat. Thanks for your reply.
Old Oct 17, 2013 | 06:41 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Sounds like they are selling you a fourth gen seatbelt with a cover for the missing lower RETRACTOR. Please let us know how it fits, usually using fourth gen belts requires some modifications.
Old Oct 17, 2013 | 06:17 PM
zenish's Avatar
Engine: 305 tbi
i hope vert seatbelts are coming.
Old Oct 17, 2013 | 08:36 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
For the female recievers you need a #50 torx bit.
(I just replaced mine)
I can only assume the uppers and lowers are the same size.
Old Oct 18, 2013 | 09:26 AM
Steve86TA's Avatar
Car: To many to list
The lower retractor is a T50 also. The upper retractor behind the headliner is 2 -13mm bolts
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
