Ceiling/headliner rusted up
Old Oct 28, 2013 | 03:46 PM
pontiacdog's Avatar
Car: '86 Trans Am
I realized my headliner was sagging and as I removed it, I found out why.
Somehow water has been pouring in for years and now the ceiling is rusted all over.
What to do?
Pictures:
http://static.ylilauta.org/files/o9/...g/IMG_1831.jpg
(The black stuff is former rust that I sanded down and applied "Rust Converter")
http://static.ylilauta.org/files/7y/...seonruoste.jpg
(The red line indicates how far the rust has spread)
The problem is, there are areas with 2 layers of metal and there is rust in between. I can't apply rust converter or sand the area because it's so narrow.
I could just leave it be and install a new headliner.. but at the very least I have to figure out where the water is leaking from.
Old Oct 29, 2013 | 06:49 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Ceiling/headliner rusted up
have you tried any of the aerosol rust converters? eastwood has a product used specifically for inside of car frames. its an aerosol can with a flexnozzle on it. maybe try it?
Old Oct 29, 2013 | 07:42 PM
Twin_Turbo's Avatar
most likely it's condensation on a cold roof, do you have fogged up windows when it's raining?
Old Oct 30, 2013 | 07:09 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Most of the hard tops I have pulled have this problem. Condensation is the culprit and the underside of the roof doesn't get much paint .
I would wire wheel and sand the rust, then use POR 15.
Be best to do this with interior removed or well covered.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
