How do I straighten a crooked center console?
Old Oct 27, 2013 | 11:18 AM
Gen X T/A's Avatar
Car: 1987 Pontiac Firebird Trans Am
Engine: LB9
Transmission: Turbo Hydra-Matic 700R4
Axle/Gears: 2.73 limited slip differential
My center console (radio and A/C control housing) is not aligned straight. It's like it's slightly swiveled to the right so the front is slightly aimed towards the passenger, and a small amount of the rear of the enclosure sticks out into the driver side foot well. What's the best way to approach fixing this?
Attached Thumbnails How do I straighten a crooked center console?-ta15.jpg   How do I straighten a crooked center console?-ta16.jpg
Old Oct 27, 2013 | 01:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: How do I straighten a crooked center console?
It appears that your radio pod might be broken where the mounting bolts go.
Old Oct 27, 2013 | 09:52 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Definitely the case. They seem to be broken on any Firebird that's been driven. The mounts are incredibly flimsy for the amount of weight they are supporting.
Old Oct 28, 2013 | 12:24 PM
Gen X T/A's Avatar
Engine: LB9
So which commonly breaks? The mounting hardware or the radio pod itself?
Let me guess, anything less than smooth road surfaces eventually rattles this stuff apart?
Old Oct 28, 2013 | 12:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
The pods frame,it plastic,you could get away with a nice size washer.
Old Oct 29, 2013 | 08:52 AM
Engine: LB9, LS1
Basically. I took mine out and epoxied it. Unfortunately, that broke too, so i bent some steel to fit with the frame and hold it together.
Old Oct 30, 2013 | 10:17 AM
Gen X T/A's Avatar
Engine: LB9
The service manager at my Buick/Pontiac dealer took a look at it for me. According to the invoice:
CUSTOMER STATES CENTER CONSOLE IS NOT ALIGNED
CANNOT ALIGN CENTER CONSOLE DUE TO BROKEN BRACKETS
He claims the mounting brackets are broken, and they are no longer available from GM, so he did what he could, which was almost nothing, and buttoned it back up, no charge. Wish he would have snapped some pics.
Old Oct 30, 2013 | 10:18 AM
Gen X T/A's Avatar
Engine: LB9
Good to know. I'll make a project out of it and remove the pod to see what's going on inside and take it from there. They obviously did not manufacture this part to withstand age + vibration.
Ed1LE
Sep 30, 2018 09:14 AM
Lbibb
May 5, 2016 12:00 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
