Rear Weatherstrip and Interior Exhaust Smell
Old Oct 31, 2013 | 01:49 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
My car runs a bit rich with the carb setup. After driving with the windows up, i'll come into the house smelling like an exhaust pipe. I believe the rear hatch weatherstrip is original to the car.
If I replace the weatherstrip, do you think that'll resolve the issue?
Just curious if anybody else had a similar experience.
Old Oct 31, 2013 | 03:46 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Rear Weatherstrip and Interior Exhaust Smell
you really have to do more than that ,make sure the hatch glass is aligned to the aperature.make sure the exhaust is correct.make sure the body has no holes that fumes can enter. then a new hatch seal should help.
Old Oct 31, 2013 | 04:20 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Also IMO I would probably tune up the ignition and carburetor so she isn't running so rich. After I did that I would get that oil changed. Probably has a lot of gas in it.
Old Nov 1, 2013 | 10:51 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I'll give it a shot guys, thanks!
Old Nov 2, 2013 | 07:26 AM
rs coastie's Avatar
Car: 91 camaro rs
Engine: tbi 305
Transmission: 5 speed
is your hatch pull down working?? if its stuck in the up position, like so many are it wont let the hatch press down and seal properly.
Old Nov 2, 2013 | 09:55 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Not unless it is damaged or compressed and lost its resilience. If you can push the hatch down or hear noise through it then it could be as mentioned above. Had it happen before, but no exhaust smell though.
If you have exhaust smell I would look for a leak, or extend the exhaust out the back farther.
IIRC, a rich carb smell can also be caused from disconnecting the charcoal canister.
https://www.thirdgen.org/forums/tpi/...ove-vapor.html
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
