Shift knob?
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Shift ****?
I am absolutely in love with this shift ****, can ANYONE tell me where I can find one? I will love you forever if you find a source
http://www.hotrod.com/featuredvehicl.../photo_04.html
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Shift ****?
Ahhh...... Not that I need anymore luv'n......
I had nothing better to do so did a full on image search, Google-Yahoo-MSN then went through 46 pages on AOL.....
I'ma gonna go out on a limb here and say..... That may be a one off ****.....
Good Luck !
Good Luck !
Car: 1991 Camaro RS
Engine: 5.0 L03
Re: Shift ****?
I have found a few that have the same body shape (the cut circular rings) but not the same top, I may just buy one and have a machine shop have at it. Thanks though!
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Shift ****?
i've seen then used on the NASCAR circuit, it has 2 featured purposes for them. One is heat dissipation , second is weight.
Night rider327
Feb 25, 2016 09:50 AM
