Open wires under dash... What should I do?
Car: 85 berlinetta
Engine: Edelbrock 350
Transmission: Stock
So, the light in the drivers floorboard met an untimely end (I cut off the entire socket & bulb when I was cutting out a different wire, oops.)
So now I have 2 bare wires just chilling under my dash, so I came here for suggestions as to what to do with them.
Please no crazy ideas. Something functional and not hillbilly-esque preferably.
Thanks!
Thanks!
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Open wires under dash... What should I do?
Wrap them,before they get shorted out.
Car: 85 berlinetta
Transmission: Stock
well I did that. I was talking about using them for something new in the car. I don't like having useless wires. Haha.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
rewire the bulb?
or wire in an LED strip to have some kind of floor lighting
Car: 85 berlinetta
Transmission: Stock
The bulb seemed pretty useless.
I'm thinking about running an led strip up to my gauge cluster so I can see them better, or something like that, but something unique would be fun to do.
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
not sure that is going to help much, as i think you have to have the dome light on for that to be lit (unless i am thinking about the wrong light)
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
As indicated above, that power source is switched with the dome light so not much use for anything besides courtesy lights.
If you don't want footwell lights, you could wire it to door sill or puddle lights as I've seen here on the forum recently.
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
