how to remove interior door handle/lock trim panel thinggy....
Old Feb 19, 2014 | 09:05 AM
Nickmiceli7's Avatar
Car: 1991 Firebird
Engine: stock 305
Transmission: Stock auto
Axle/Gears: stock
Lol 91 firebird auto windows and locks.. does the panel around the inside handle and lock buttins just pop off or is there a scew somewhere?
Old Feb 19, 2014 | 10:36 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: how to remove interior door handle/lock trim panel thinggy....
first off you have to take out all the screws, then pop the lock indicator button thing off, I like to use a flat head screw driver and pry it off. then the whole thing should slide off. pretty simple
Old Feb 19, 2014 | 11:43 AM
Car: 1991 Firebird
Engine: stock 305
Axle/Gears: stock
Well there are no visible screws..?
Old Feb 20, 2014 | 12:36 AM
83HOZ's Avatar
They're not visible. There are two screws in each trim piece, one behind the bird emblem, and one behind a small round cap in the recessed area behind the door handle.
Attached Thumbnails how to remove interior door handle/lock trim panel thinggy....-fbirddoorpaneltrim.jpg
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
