how to install hatch nylon guides
Old Feb 21, 2014 | 10:34 AM
tarouty's Avatar
hello
hatch pull down motor nylon giudes are broken
how to install the new
There are side thick and thin side
There is code I and code O
Attached Thumbnails how to install hatch nylon guides-nylon.jpg   how to install hatch nylon guides-screenshot_2014-02-21-19
Old Feb 22, 2014 | 03:26 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: how to install hatch nylon guides
Originally Posted by tarouty
hello
You didn't get the 4 page instruction sheet with them? The I go on the inner two, the O go on the outer two tracks. They are designed so you can customs fit them, as needed, (O, I, O, I) will allow for more clearance to outer two tracks and less on inner two. (I, O, O, I) would give you the most clearance to the outer two tracks and the least clearance to the inner two tracks. E-mail me and I'll send you the instruction sheet.
Lon Salgren
topdownsolutions@yahoo.com
Old Feb 23, 2014 | 03:27 PM
lonsal's Avatar
The information in the instruction sheet I've mentioned which comes with the guides is also available as a Tech Article that I wrote and has been posted here on Thirdgen.org for nearly 12 years.
Read the Tech Article and you'll know how I recooemd installign the guides.
https://www.thirdgen.org/tech/hatchpulldown.pdf
Lon
Old Feb 23, 2014 | 03:28 PM
lonsal's Avatar
Read the Tech Article and you'll know how I recommend installing the guides.
Lon
Old Feb 25, 2014 | 08:10 AM
tarouty's Avatar
Thank you for your help
It is clear
THANKS
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
