Heater core access 1987 with A/C
Old Feb 23, 2014 | 05:32 PM
Irocblast's Avatar
Car: 1987Iroc
Engine: 5.7
Hi, i have purchased a 87 Iroc with A/C I am just putting the finishing touches on getting it ready for spring driving. When I purchased it was sitting for about 5 to 6 years and mice built numerous nests inside I have found all except one in heater box turn on the blower and wow it really smells BAD Does any one have a exploded view of heater core removal with A/c that is where they I think they have made good size home Any guidance will be appreciated.
Old Feb 23, 2014 | 08:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Heater core access 1987 with A/C
These are for the Firebirds 82-89.they'll give you an idea in what you have to do
Hope they help.
Old Feb 23, 2014 | 08:23 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
access to the heater core is no sweat. pull the hush panel and you will see a box, this box has about 6 or so 7mm screws. the hardest to reach is the one on top. on birds we can pull the panel just under the pouch and use a flexi-stinsion to access it.
once the box is of you will see the core that is held in by a frame and 4 7mm screws. with the hoses off in the eng bay this frame will come out fairly easy. this will allow access to the core area and to the other side of the core for cleaning.
you DO NOT need to re move the dash pad for any of this.
Old Feb 24, 2014 | 04:15 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
You don't need to remove the dash pad, but it makes it much easier to get the top screw of the heater box. Unlike the Firebirds, the top screw on the box is not easy to get your hands on. I found that if you take the dash pad off and remove the speaker, you can get your hands in there easier to get the screw out and back in. I also find it really easy to work on with the front seat removed. A few extra minutes to remove the seat and dash pad will make the job so much easier and less frustrating. It will take you longer to get the screw out by not removing the dash pad then the entire removal and re installation combined.
Old Feb 24, 2014 | 06:04 PM
Irocblast's Avatar
Car: 1987Iroc
Engine: 5.7
Thanks alot for your timely response
Old Feb 24, 2014 | 06:05 PM
Irocblast's Avatar
Car: 1987Iroc
Engine: 5.7
Thanks you for the help
Old Feb 24, 2014 | 06:06 PM
Irocblast's Avatar
Car: 1987Iroc
Engine: 5.7
Thanks for the help
jrdturbo
Mar 31, 2016 02:58 PM
David Frans
Oct 31, 2015 08:12 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
