Rear hatch motor will not stop trying to pull down
Old May 29, 2014 | 05:02 PM
IROC-Z Forever's Avatar
Car: 1987 IROC-Z T-Tops
First time posting but long time reader of the threads and has been extremely helpful anyway, in my 87 iroc I went to close the rear hatch and it pulled down just fine and wouldn't stop trying to pull it down so i grabbed my keys quick and unlocked the latch (doesn't work from switch in interior) and the motor stopped trying to pull down. When I press the little black switch that tells the hatch to operate, it will just keep on running and I can't get the motor to go back up. I don't know if there is a sensor in there that senses when it is all the way down that could have went or something stripped in the motor. I saw something about a plastic screw that strips but i don't think thats the case... Help would be very much appreciated!!!
Old May 29, 2014 | 05:13 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: Rear hatch motor will not stop trying to pull down
Mine did this and it was the plastic gear housing had broken.
Old May 29, 2014 | 05:27 PM
How easy is it to tell if its broken? I can't look at it right now but can when i get home, and how much would a replacement be if they even make them?
Old May 30, 2014 | 09:48 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Remove the rear panel and its all right there. Here is one solution.
http://www.top-downsolutions.com/hat...own-repair-kit
Old May 30, 2014 | 09:54 AM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
You might as well rebuild that whole thing while it's out. It's around ~$140 shipped for the rebuild kit which includes the motor (I think the link posted above is it) and everything else you need. A rebuilt one or to have yours rebuilt will run you easily into the 250-350 range. Simple tools and a simple job. Hopefully you disconnected power to the motor to prevent it from burning up or killing your battery...
Old Jun 1, 2014 | 10:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
From the description the problem could be as simple and inexpensive as the gear nut broke. It is available on my web site. Follow the repair instructions I posted over a decade ago here on TGO:
https://www.thirdgen.org/tech/hatchpulldown.pdf
Lon Salgren
Old Jun 8, 2014 | 08:12 PM
91Z28fan's Avatar
Here is what a friend did on his Camaro. Hope it helps.
http://www.top-downsolutions.com/hat...-Pull-Down-Kit
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
