A-pillar trim.. again
Old Jun 7, 2014 | 09:09 AM
pontiacdog's Avatar
Car: '86 Trans Am
Once again I would need tips and information on installing the a-pillar trim..
(It has already been established that they are very hard to remove without breaking any clips or tabs.)
1. How do I remove the white clips from the a-pillar? A couple of them are broken but they just won't come out no matter how hard I pull on them with pliers.
2. How do I install the trim piece?
I actually tried to use x-mas tree style clips instead of these weird rails to make installation and removal super easy but it didn't work out, they will never fit the slot.
Old Jun 9, 2014 | 02:58 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: A-pillar trim.. again
There's a locking tab in the center of the white clips. You've got to move the locking tab forward or back ( depending on how they were installed ) before the clip can be pulled out of the A Pillar. A small screwdriver works best IMO.
Break that locking tab and the clip will fall right out.
Tree style 'push' pins do not work very well.
aharvel50
Sep 21, 2015 07:31 PM
WECoyote
Aftermarket Product Review
35
Apr 21, 2002 09:41 PM
RMK
Nov 19, 2000 08:17 PM
JEFJM
Oct 16, 2000 08:49 PM
