85 firebird base steering wheel size??
Car: Gold 85 Firebird w/ T-Tops
Engine: 2.8 :(
I have an 85 bird and like usual the steering wheel is garbage. I'm thinking about buying a cover for now bcz it needs a new column. How big is te stock steering wheel? I work out of town an my car is three states away.
Thanks in advance
Thanks in advance
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 85 firebird base steering wheel size??
The 85-87 3-spoke leather Trans Am steering wheel is 14" (across the center). I've got one, not perfect - but pretty good shape.
I've 1 Grant Steering Wheel that's 13" "(across the center) and a second one (different style) that's a little bigger than 13". Seems like every aftermarket wheel I see is smaller then stock.
Figure this might be worth mentioning; I've got a good steering column (tight TILT) that's already got a GRANT steering wheel adapter installed on it. It's a fully 'loaded' column from an 86Z with Delay and Cruise Control; and the 2 Grant wheels,..... When your ready to replace the failing parts on your ride feel free to send me a PM, I might still have what you need.
backtothe80s
Sep 5, 2015 12:39 AM
