window mounts
Old Aug 23, 2014 | 12:32 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
window mounts
Years ago when I got the car the window had broken off the track. There were white plastic pieces that where broken. I ended up using a couple washers and cotter pins to get the job done temporarily to keep the window up. Well I'm finally wanting to fix it properly so my window stays tight. There's some play in it. Anyways. Where can I get replacement parts for this
Old Aug 23, 2014 | 02:16 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: window mounts
heres a pic
Old Aug 25, 2014 | 06:29 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: window mounts
That's probably a bone-yard item.
Old Aug 25, 2014 | 07:00 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: window mounts
same issue here. I made some out of plastic and rubber and used bolts and nuts. seems to be working well. been like that for 5 years.
Nick McCardle
Sep 10, 2015 08:36 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
