Where to find the brush-bristle things for the e-brake hole?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Trying to find a source for the brush bristle looking things for the e-brake hole on my 82-84 Firebird console.
Any sources for it new?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Where to find the brush-bristle things for the e-brake hole?
I can't find a P/N for that and I don't know how the workings go under there,but you may be able to use something like door sweep material.
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
With all the restoration parts available I'm surprised this isn't made! I'm sure every third gen will need them.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Bump! Still haven't found proper restoration parts. Can't imagine they don't exist!!
Car: 88GTA
Engine: 5.7TPI
I know this ain't no help but...
I seen on here a while back somebody posted the same for the rear pull
down bristles things. They were available form somewhere. This ought to be in that same catagory. IDK
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hmm, cool to know someone did find something, that's promising!
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I have my center console out for some interior wiring work this past winter and I thought about replacing mine too. The problem is the way they are mounted. They aren't in a plastic holder like the trunk ones are. The ones in the trunk just slide in and out of the holes in the plastic trim piece.
Unfortunately the ones on the ebrake handle are mounted permanently. It looks like they were placed over plastic pins that are molded into the underside of the console, then those pins were melted down to secure the bristles in place. To replace them, you would need to grind down the tops of the melted pins and pull them out. This wouldn't leave any way of mounting new ones without drilling holes through the top of the console to bolt or screw them in place.
