1990 IROC Steering Wheel Air Bag
Old Dec 11, 2014 | 09:12 PM
dale3in98's Avatar
Hi,
I am new to the 3rd Gen. scene and have and have a question about the steering wheel air bag/cover.
Can the cover only be replaced or is the air bag and cover one piece?
Mine is starting to curl up on the edges.
Thanks,
Mike
Old Dec 12, 2014 | 12:19 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: 1990 IROC Steering Wheel Air Bag
I'm pretty sure it's not serviceable. You will need to replace the entire airbag assembly.
Old Dec 18, 2014 | 01:01 PM
RSValor91's Avatar
Car: Maros: 89 Z28 & 91 RS
Engine: 350 TBI & 305 TBI OEM
Just one piece, must replace all the airbag!!
Old Dec 18, 2014 | 06:43 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Nobody makes them from what I found. I ended up putting a 4th gen wheel on my 91. There are tons of them in junkyards and they are usually in much better shape than the older thirdgen bag wheels. The bag connectors are slightly different though. So if you go this route you'll need to clip the connector from the column of the donor 4th gen car and solder it on your thirdgen column.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
