What Window motors to get
Old Jan 15, 2015 | 10:12 PM
DJanes97's Avatar
Car: 83 z28 crossfire camaro
Engine: Now a carbed 350
So long story short a few hours ago I rolled my passenger side window down. Well I showed up at the car wash and realized it wouldn't go back up. I shut the door decently hard and that finally did the trick. Now I'm afraid to roll that window down till I order new motors. Well I've looked at rockauto and am wondering which one you guys all suggest? There's 6 different motors listed and I don't know if there's an differences. I've done some research and can only find that people suggest rockauto. Can't find which ones they suggest from them though. Any suggestions would be appreciated.
Old Jan 16, 2015 | 12:34 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: What Window motors to get
https://www.thirdgen.org/forums/spon...=window+motors
Old Jan 16, 2015 | 06:05 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
If I recall, their nicer ones (not cheaper ones) have a lifetime warranty.
Old Jan 16, 2015 | 08:15 AM
mantaguy's Avatar
Engine: 5.0 EFI
I posted the wrong one on the 1st post.,Sorry.
Old Jan 20, 2015 | 10:08 AM
Camaro_383's Avatar
Car: 92 25th Anniversary RS
Engine: 5.0 TBI 305
It could be multiple simple problems. It might actually be the motor going bad, or it can just be a ground problem in the wiring, which is why it starts to work when you shut the door really hard. Or you could have the same problem like mine and that would be the rubber stripping that guides the window up could be rotting and it prevents it from going up sometimes
Old Jan 20, 2015 | 10:13 PM
DJanes97's Avatar
Thanks for the tips. My dad and I are about to rewire them and put relays in. If that helps ill just run the motor till it goes bad but if not I guess I'll have to get a new one. I don't even mess with that window now because I'm afraid it will go down and be stuck down. I was just curious if certain brands were better then others or if it was just warranty stuff.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
