85-92 center console light
Old Mar 13, 2015 | 08:23 AM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I had a working center console light. But during my interior swap, I accidentally opened it, causing it to no longer work. I have all the parts, but do not know the correct way to put it back together.
Old Mar 13, 2015 | 09:29 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 85-92 center console light
Do you need a switch?or do need how to put it back together?
Old Mar 13, 2015 | 09:51 AM
t/aws61985's Avatar
Engine: Slow ones
I just need to know how to put it back together.
Old Mar 13, 2015 | 10:41 AM
mantaguy's Avatar
Engine: 5.0 EFI
http://i166.photobucket.com/albums/u...psffbpscxr.jpg
http://i166.photobucket.com/albums/u...psqypxhqo0.jpg
http://i166.photobucket.com/albums/u...psvzolrnnz.jpg
Old Mar 13, 2015 | 11:47 AM
t/aws61985's Avatar
Engine: Slow ones
Thanks for the pictures. But I need to know how to put in back together fully, I pulled the top off and the insides just fell out. There are 2 contacts for the light bulb, and a spring. Every time I try to put it back together it's always something. Like the push out tab will be tough/stuck out or in, or the light won't work but the push out tab will fuction fine. I already blew 2 fuses trying to test it lol.
Old Mar 13, 2015 | 01:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
I would take this one apart but it's the only spare I have.All I can say is,if it's blowing fuses it's shorting out inside that switch,are the two wire for the plug in the same way they came out?
Old Mar 13, 2015 | 07:21 PM
t/aws61985's Avatar
Engine: Slow ones
I just got it to work. Idk why I had so much trouble with it. Here is a picture of how the metal is supposed to be placed. hope it helps people in the future.
Attached Thumbnails 85-92 center console light-11051421_773532996077120_672856219_n.jpg
Old Mar 13, 2015 | 07:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
I knew you would get that,not to much in that switch.It's kind of like the insides of the Upper Console flashlight.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Firebird sweden
Aug 16, 2015 05:02 PM
