Any advice for those removing door panel with windows up?
Old Mar 16, 2015 | 07:27 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Like the title says, I'm trying to remove the door panels on my 91 GTA so I can replace the window motors but I'm having to do mine with the windows up. Every how-to procedure and video explains/shows it as being very easy with the windows down but unfortunately for me, my windows won't go down. Not even an inch. Are there any tips or tricks to remove the door panel with the window in the up position to make this easier? I'm having a hard time getting anything to budge other than the outer edges.
Old Mar 16, 2015 | 08:28 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Re: Any advice for those removing door panel with windows up?
It was a major PITA, but I was able to successfully remove them in damaged. I believe it was a combo of everything listed, but #2 is very important, I used a few extra long screw drivers to keep them unclipped while moving to the next.
https://www.thirdgen.org/forums/inte...s-without.html
Old Mar 17, 2015 | 09:21 AM
Car: 91 GTA
Axle/Gears: stock
Thanks for posting that thread. I'll try some of those techniques tonight when I get home. Do you remember how many clips there are?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
armybyrd
Dec 5, 2015 09:22 AM
Out-Cast
Aug 23, 2015 06:33 AM
