Headliner Glue?
Car: 1984 Camaro
Engine: V6 2.8
Headliner Glue?
Hey guys!
I used a headliner glue 3M I Think it was, anyways 20 bucks a bottle and that sh** wont hold that well / surface was clean followed the instruction to the T. what do you guys use for that? and how well does it hold?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Headliner Glue?
I used NAPA Heavy Duty Headliner Carpet Adhesive, made by Permatex.Worked pretty good, it comes out of the can different than 3M,It looks like silly string. I never had any trouble with any 3M Product, I know when I use the 3M Spray I let it get tacky first before I Lay anything down.
Re: Headliner Glue?
The Permatex mentioned above works well and is a few dollars cheaper than 3M.
3M makes several "headliner" glues. Most people make the mistake of getting the wrong one. None of them will work properly except the Super Heavy Duty Spray Adhesive. Hint: it comes out of the can like silly string also.
I keep both the 3M and the Permatex on the shelf.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Re: Headliner Glue?
Yeah, I have to agree, you may have got the wrong headliner glue from 3m. I know I used a few different ones that didn't bond for crap. Then when I replaced mine in my Fiero in early 2000 the kit came with a heavy duty 3M headliner spray. Then when I replaced the liner in my Z in 2005 I used the same stuff. In both cases, the headliner is still holding strong with no sags or separations at all. Oh yeah, and that's also considering both cars have endured many years of AZ hot summers.
I know you said that you followed the directions closely but if you used the original headliner board, I hope you paid extra attention to getting all the foam off of it, if not, it doesn't matter if you slather the glue on with a brush, it won't stick very well.
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Axle/Gears: 10 bolt torsen diff 3.73
Re: Headliner Glue?
Get a decent contact cement. You can brush, roll, or spray it on. All you have to do is cover both surfaces with a very thin layer, wait for it to dry enough that it doesn't leg to your finger, then stick them together. Good luck getting them back apart.... It's very permanent.
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
