Rear hatch motor problems
Old Mar 30, 2015 | 02:32 PM
jdost1992's Avatar
This is for a 92 RS
Mine crapped out quite awhile ago so I rigged it up to where I could just shut the rear hatch and open it with my key. I decided I wanted it to work again so I found an entire new/used unit on ebay. Bolt it down and plug in that one 5 wire connector. Shut the hatch, and the motor pulls it down like it's supposed to, sweet. Try my key and it opens up just fine. Close it again and push the button inside the car and the motor goes up, then right back down and doesn't release the hatch at all. (hope that makes sense)
Any ideas why when I press the button the motor goes up and down without releases the hatch?
Old Mar 30, 2015 | 04:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Rear hatch motor problems
Sounds like you need better struts.
Old Mar 30, 2015 | 04:16 PM
jdost1992's Avatar
Struts are pretty much brand new, only couple months old. Hatch pops up just fine when I open it with the key.
The motor moves up then immediately down when the button is pressed, but it isn't releasing the hatch when the button is pressed.
Old Mar 30, 2015 | 07:39 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Mine is doing the same thing. I figured it was the spring in the latch.
Vintageracer
Jan 10, 2020 05:33 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
