Footbed Lighting Power Source?
Old Apr 2, 2015 | 07:58 PM
Z28_1991_Camaro's Avatar
Car: 1991 z28
Engine: 5.7L
I want to put some led strips in for footbed lighting in my car, I was wondering where would be the best place to splice into for power?
I am thinking of splicing into the radio this way the lights can't be left on accidentally(I know there are two different power feeds going to the radio and one is always on). I don't know much about this stuff but would I need to add a fuse or would I be ok without one?
Is there a better place to get power from or is the radio a good choice?
Old Apr 2, 2015 | 09:07 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Footbed Lighting Power Source?
Where to tap in depends on how you want to control it. If you want to put a switch in, then the radio ignition feed is fine. Personally, I would wire them off the parking lights wire from the headlight switch. That way you can't leave them on, and they come on automatically at night.
A fuse is always a good idea, especially if the light strips can't handle more than a couple amps. I believe the radio has a 10 amp fuse, and the parking lights a 20 amp fuse. The LED strips I installed recently required a 5 amp fuse, yours might be different though.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
