Ignition lock cylinder question
Old Apr 8, 2015 | 04:31 PM
Big, White & Sl's Avatar
Car: 86 Camaro
Engine: 355
Transmission: Powerglide w/brake
Axle/Gears: Currie 9" w/4.56
Background: The lock cylinder in the 89 GTA I bought was messed up and the VATS was already bypassed. So, I took the lock cylinder out of my 87 GTA parts car and put it in. It wouldn't turn the ignition far enough to engage the starter. I thought the ignition rack was bad and tore the column apart to check and everything was good. While it was apart I put the cylinder on there and everything was good. Get it back together and same problem. For the hell of it i slide the original back in and presto!
I checked out the 2 cylinders and it appears that the 89 cylinder turns just more than 45 degrees and the 87 just less than 45 degrees.
Anyone ever seen this?
What cylinder do I need? As i said, the VATS is bypassed. I'm gonna try and find a GM one on ebay, but I dont want to get one thats the same as the 87
Old Apr 9, 2015 | 09:23 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Ignition lock cylinder question
82-88 and 89-02, so you need a 89-02 Camaro w/vats
Old Apr 10, 2015 | 03:29 PM
Car: 86 Camaro
Engine: 355
Cool. Thanks
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
