power window trouble
Old Aug 14, 2015 | 10:44 AM
pfsteichen's Avatar
Car: 92 Z28 convertible
Engine: 305 tpi
Transmission: Auto matic
The passenger side window of my 92 Z28 is very slow and frequently stops about 2-3 inches from full close. Then after letting it sit a few minutes it will slowly go all the way up. My question is do I need a new motor for the window? Or is it a dirty track that can be cleaned? If I can find out prior to taking the panel off that would be great. Thanks for any help in advance!
Old Aug 14, 2015 | 11:28 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: power window trouble
Both. The motors are relatively cheap. Clean the track all up and you'll be good to go.
And you'll need to take the door panel off for both.
Old Aug 16, 2015 | 12:14 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Check the felts at the top of the door.They can be loose when the window is down, but tight when rolled up.They should be adjusted when the window is no more than half way up/down.
Old Feb 7, 2016 | 01:38 PM
pfsteichen's Avatar
Engine: 305 tpi
Well I uncovered my car today and pulled off one door panel. I bought some white lithium grease. Is it worth it to try and clean those window tracks first or just start working the grease into them?
Old Feb 9, 2016 | 06:59 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
If the old grease is part of the problem, I'd make an effort to remove what I could of it.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
armybyrd
Dec 5, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
