Shifter boot
Old Nov 16, 2015 | 12:52 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Shifter boot
What are yall usin for replacement shifter boots on the 5 speed cars? Mine is ripped and way worn out.
Old Nov 16, 2015 | 01:39 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Shifter boot
I made a new one for my camaro. I removed the old one, and carefully cut the threads along the seams to separate the four pieces. Using those as a pattern, I cut out new pieces from some red suede and black fake leather. Sewed them together on my wife's machine and reattached to the shifter plate. It's not perfect as my sewing skills need practice, but came out looking a lot better than the original.
Old Nov 16, 2015 | 05:28 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Shifter boot
I'm working on making my own and then possibly making more to sell. I need to find a better machine though cuz mine is a pos... ;-)
Old Nov 16, 2015 | 09:27 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Shifter boot
Old Nov 16, 2015 | 09:29 PM
mjdavis68's Avatar
Re: Shifter boot
Ebay is where i got mine
Old May 22, 2016 | 05:55 PM
BradS(IL)'s Avatar
Re: Shifter boot
Mj,
Do you know what seller or what to search for to find another one? I haven't been able to find a leather shift boot for an automatic.
Jharrison,
Let me know if you have anything for sale, too.
Old May 22, 2016 | 09:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Shifter boot
You can make it too.
Old May 23, 2016 | 06:52 PM
BradS(IL)'s Avatar
Re: Shifter boot
nice! Looks like you had to modify the shifter base plate, how much did you cut out and what did you use to make a nice cut in the plastic shifter base?
Old May 23, 2016 | 08:40 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Shifter boot
Yes, modified.Never measured I just matched the length of the window to the shifter & the edge the same width as the section between window/boot.Its all hand cut w/ an exacto knife, filed flat.
Old May 23, 2016 | 08:51 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Shifter boot
redlinegoods.com
Old May 30, 2016 | 03:16 PM
sahlomonic's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
Re: Shifter boot
I'll update with pics later, but if you're wanting to add a shifter boot to an automatic in the Camaros (almost Firebird/Corvette style), there is a way to do it and still retain the shift position indicator. I did it to mine and was actually pretty easy. I just got one off eBay and I think it's from a Firebird but not certain. Basically just sandwich the leather between the plate and the plastic piece glued underneath it (which you'll have to break off and re-glue when you get the leather between it)
Old May 30, 2016 | 03:24 PM
sahlomonic's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
Re: Shifter boot
Old May 31, 2016 | 06:26 AM
BradS(IL)'s Avatar
Re: Shifter boot
Originally Posted by sahlomonic
Awesome. That is what I'm looking for! Thanks
Doobie52
LSX and LTX Parts
Nov 18, 2021 11:02 AM
lbdz28
Feb 4, 2016 09:46 PM
Necron
Nov 14, 2015 07:07 AM
Batwill
Nov 13, 2015 09:48 AM
