Driverside window keeps tearing up the outside window trim
Old Dec 11, 2015 | 10:36 PM
85RS's Avatar
Car: 85 Camaro RS
Engine: GEN I sbc 5.7, .040 over
Transmission: 700R4 Slushbox dreamkiller
Axle/Gears: 3.42 posi
My driverside window keeps tearing up my outside trim on the door and pulling the inside trim piece off the door panel. The window isnt off track but acts like its coming up at the
wrong angle, its also very loose like it missing a guide or something. Everything seems to be in place (felt and track, but it acts like its out of place. Any insight on this?
Old Dec 11, 2015 | 11:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Driverside window keeps tearing up the outside window trim
Could be the outer trim piece is missing the screws to hold it inplace & the inner trim is broken off the door panel itself.That said, how does the glass seal against the weather-strip?
Old Dec 14, 2015 | 03:17 PM
85RS's Avatar
Car: 85 Camaro RS
The outer piece keeps getting ripped off the door. Ive replace all the screws for the outer piece but when i roll the window, it comes up under the outer trim piece instead of under and beside it. Like it literally comes up directly beneath it as if the window is somehow out of track but ive looked, its still on its track, just wobbly. It seals fine as long as i push the trim back against it after rolling the window up.
Old Dec 14, 2015 | 09:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I would guess the window needs adjusting.Hard to tell by your description or pics whats the issue.
Coolball
Dec 21, 2015 03:44 PM
mustangman65_79
Dec 15, 2015 04:18 PM
jorgeblancojr
Dec 11, 2015 11:33 PM
claw87
Dec 11, 2015 07:45 PM
Napalm
Dec 6, 2015 08:36 AM
