Dash fitment.
Dash fitment.
Hello. Ok I have an 82 Trans Am. The body shell is rusted out really really bad but everything else is really nice. So I bought an 86 trans am pretty well stripped but SOLID body and clean title. It's even same color. I am transferring everything over to it. Fenders, suspension, rear end, motor trans. Anyway I bought a new carpet for the interior. So my question is will my 82 dash bolt into the 86. I'm talking the entire dash assembly not just the dash pad. Any knowledge about this would be helpfull. Thanks.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Dash fitment.
Yes it should. The size and look of the dash assembly and interior changed, but the mounting points are still the same. However the electronics, such as the instrument cluster, will not hook up the same. Firebirds switched over to electronic gauges in '85 so your '82 gauges will not work with the '86 harness.
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Re: Dash fitment.
If you are changing all the hardware, engine, electrical, computer, trans, as jharrison says, you must transfer the wiring, or buy a new harness. but be sure it is for the original running gear.
87_gta
Jun 11, 2017 11:50 PM
evo-offer
Mar 18, 2016 11:04 AM
AmpleUnicorn88
Feb 25, 2016 06:19 PM
Camarokid00
Feb 21, 2016 09:00 PM
